Timed Flash and Fade times interaction ?
Posted: 10 Jul 2017, 00:22
I'd like to achieve the following but I'm getting an unexpected (to me !) interaction of fade time and flash time:
1. When manually fading down an intensity on a fader I want a fade out time of 0.5s
2. When the fader is not zero and I hit the flash button I want to snap to full intensity and fade back to the current fader level in 0.5s
3. When the fader is at zero and I hit the flash button I want to snap to full and then fade back to zero in 0.5s
If I use the normal flash profile with a fade out time of 0.5s then 1 and 2 work but 3 doesn't.
If I use the timed flash profile and set a fade out time of 0.5s then 1. and 3 work but 2 doesn't - it snaps to full on, then fades to zero intensity over 0.5s then snaps back to the current fader level. This is visually very distracting !
Have I missed something or is this expected behaviour ?
