Titan PC Suite 10.1 ST issue
Posted: 30 Jun 2017, 19:44
by hushhush
All simulators except the Sapphire Touch seem to be working properly and the Sapphire Touch is what I need. The ST simulator opens but all that is there is the workspace windows and fader banks on top and bottom. No ability to program. What am I missing here? Please advise
Re: Titan PC Suite 10.1 ST issue
Posted: 30 Jun 2017, 19:50
by Gregory
When running Titan Simulator in Sapphire Touch mode you will require two monitors connected to your computer, for the left and right screens of the console. If you only have one monitor you will only get the left hand screen, the softkey menu is on the right hand screen.
Posted: 30 Jun 2017, 20:01
by hushhush
Thank you, I knew I was missing something obvious!
Titan PC Suite 10.1 ST issue simulator system mode
Posted: 10 Jul 2017, 02:58
by hushhush
Is there a way to get into systems mode (to assign masters) in the simulator?
Posted: 10 Jul 2017, 08:52
by Gregory
To hold down a button on the virtual panel you should right click on them, this will allow you to use the Avo+Disk key combination or you can use the keyboard shortcut Alt+Shift+S. On most consoles you can also assign masters from the Record menu (Alt+R).
