Pearl tiger not open
Posted: 03 Feb 2017, 15:20
by sultahan
Hello there. I have a pearl tiger light table but it does not open. It shows the problem in the picture. How to follow a path is necessary. Thanks in advance.
Re: Pearl tiger not open
Posted: 23 Feb 2017, 18:56
by sultahan
Nobody can help?
Posted: 23 Feb 2017, 19:01
Have you tried contacting service?
Posted: 23 Feb 2017, 19:27
by sultahan
I'm trying to do what is written here, but every time it shows the photo in the photo. Would it be useful if I did ECN-0180?
Posted: 23 Feb 2017, 19:29
by sultahan
Whenever the power button is turned on and off, the clock is always the same. Could it be because the battery is over?
Posted: 27 Feb 2017, 14:34
by Gregory
Lee wrote:It looks like you just need to license the console. First check the battery voltage on the motherboard, with the console switched off this must not be any lower than 3.6volts. If it is lower than this you will have to replace the battery.
To license the console follow the steps below;
Save the two attached files onto a USB stick – with the console switched off insert the USB stick into the console with the two attached files saved on the stick – now switch on the console.
Once booted turn the key switch to System mode, the console will now boot into the AVOS menu from where you can get the console ID. Now go to the link below and submit a license request;
https://www.avolites.com/software/downloads/pearl-2008-tiger/license-software
I am unable to attach the files mentioned above, best thing to do would be to contact
Lee in service.
