problem storing only some atributes in a palette
Posted: 07 Sep 2016, 01:16
hello
I have used a Pearl Tiger for some years. I was used to store a pallete only with the attributes that i have change.
Example on the Pearl Tiger:
I can save a position palette only with pan value or tilt value.
I can save a color palette on a LED fixture with only one color from the rgbw. So I can have a full white palette and another where white is applied on any other color.
Now i have a Quartz with Titan v10.
When I save a "position palette" only with "pan value", the quart saves the "tilt value" as well.
Same problem when I try a "color palette", it saves all the values from the "color", even the atributes that i don't whant to be saved in a palette.
Where and what must I change, so a palette is saved exactly with the values I try to record and not all the values from all attributes in "color" or "position" ? I didn't try yet the exclude function, because it is time consuming, I whant the console to save by default only the values that I edit.
Another problem with palettes that I have notice is that some times when i press a number on the keypad to change the next palette fade time the quartz dosen't apply the color palette from the palettes on the touch screen. If I don't press a number on the keypad, than the palette from the touch screen is always applied. I didn't notice this problem with the position palettes.
Any ideas ?
Any ideas ?
