Problem with chase speed
I have pearl 2000 with 2004 soft. And the problem is when I TAP a speed for chase it will be much faster than it should be. I. e. when I tap the speed is 0,4 sec but really it is about 0,6.
I don't use the TAP button, so I've not really noticed this before...
The post caught my curiosity so I got out a metronome, set it to 100BPM which in a 4/4 time signature each beat will last 600ms. Tapping in sync to each beat and the chase runs at 400ms/step. WHAT?
I could make it run in time to my metronome by manually slowing the chase down, guess what it read when in time...600ms
The only time a step should last 400ms at 100BPM is with a time signature of 6/4...so...it must be something to do with how The Pearl is counting between each button press. I thought this was covered in a previous thread, but I couldn't find it.
This explains why only certain BPM's are allowed
http://www.avolitesshop.co.uk/phpBB3/vi ... .php?t=434
but that isn't what the OP's question was about.
Now I'm confused!
Regards,
Andy
Now I'm confused!
Regards,
Andy
John Peel
www.iadwm.com
John Peel
www.iadwm.com
niclights wrote:... easy to fix.
Unless, it's a to do with maxed out keyboard scanning and/or overworked CPU. I hope it's fixable, seems a bit daft to offer Tap tempo entry, when it's too inaccurate to use.
Regards,
Andy
John Peel
www.iadwm.com
John Peel
www.iadwm.com
Problems with chase speeds
Hi - for what it's worth, I noticed this and posted a thread about it on the Blue Room here: http://www.blue-room.org.uk/index.php?showtopic=12924 finding that others had the same problem. Glad to hear it's been flagged up!
Regards
Peter (who forgot about the existence of the Avo forum, sorry!)
Regards
Freelance lighting designer/op/technician based in Manchester - http://www.scandrett.net/
Olie - he funny!
John Peel
www.iadwm.com
John Peel
www.iadwm.com
CoenCo wrote:If he may, then I will!!!
mr
John Peel
www.iadwm.com
John Peel
www.iadwm.com
Users browsing this forum: No registered users and 67 guests
