Hi!
I'm just wondering two things about the capture in v10. Will it be possible to lock the caputre visualiser on a second screen from a console? If I have to set tilt mode on a moving head offset will the capture visualiser do that too or do I have to change it there aswell?
Anybody knows?
V10 Capture visualiser
Re: V10 Capture visualiser
The best way to keep Capture Visualiser on the external screen while switching workspaces is to ensure that all workspaces are recorded with the Leave Other Windows On Recall option and only have windows on the main screen when recording. Alternatively you can record Capture into each one of your workspaces.
Capture follows the resulting DMX output of Titan so if you apply an offset to the channel or invert pan/tilt this will effect the output to Capture in the same way as to the fixtures.
Thanks! Great support.
Users browsing this forum: Google [Bot] and 86 guests
