Pearl 2000 with MACs / HTP<P problem???
Posted: 15 Feb 2006, 14:01
First of all i have to say im not very experienced with moving lights with Pearl and im not sure if this is a problem at all, maybe it's just that i did something wrong. =) Well anyway, i'd like know why things went like they did...
Here's what i wanted to do and what happened:
I wanted to record different positions, different colors and different effects on separate playbacks. Example: Playback 1 is position 1, PB 2 is pos 2 and so on, and for example colors red, white and blue are playbacks 13-15. I also did two playbacks for controlling the shutter (open/closed)
Playbacks for positions contained only info for pan/tilt, and color PB's contained info only for color attribute. Or atleast so i thought. When recording the playbacks i didn't even touch (activate) the other attributes but the corresponding attribute for the playback. And between recording the playbacks i located the MACs and cleared the programmer ans so on.
...so this setup didn't work at all. The positions worked out fine, but every time i wanted to change a color via color playback all the macs "homed". Same thing happened with all the other effects like shutter movements and gobos. For some reason the playbacks for example color contained the info for every attribute.
I know it's a different desk, but i did all the above with Grand MA Light and it just simply worked. Now i would like to know how these things go with Pearl 2k. =)
Thanks in advance!
Thanks in advance!
