Cue recording strangness
Posted: 30 Nov 2005, 09:16
by jhld
Recently, without warning, when I record a new cue on a submaster - whatever is up on another sub gets recorded into my new cue. What gives? And why did this just start happening? Sometimes, another sub doen't even have to be up - just the last one used. This is espcially troublesome when I am trying to make a p/t or shape only cue.
re: strangeness
Posted: 30 Nov 2005, 09:37
by jhld
Oops - I forgot: Pearl 2004 with latest software.
Posted: 30 Nov 2005, 12:33
Odd. I've never seen that.
Silly question, but I assume you have made certain that the information is not in the programmer for some reason?
Does this happen even after a reset?
AFAIK the only way you should be able to store/record information without it being in the programmer is via 'Record Stage'.
re:reset
Posted: 30 Nov 2005, 23:28
by jhld
Yea, re-sets. Clear memory, yada, yada. I have never seen this before. I record as usual - record memory. Merge memory.
Posted: 01 Dec 2005, 01:54
I suggest you mail your showfile to Olie and give an example of how to reproduce.
It bight be useful to see if you can make this happen after a wipeall.
re: strangeness
Posted: 01 Dec 2005, 07:01
by jhld
I've tried a wipe all and re-install of show. I normally run as "Record By Fixture", but this problem seems to go away if I record by channel.
Posted: 01 Dec 2005, 13:57
Sorry, I wasn't clear about the wipeall. I was trying to determine whether it was showfile or desk/software related, ie. Wipeall, patch something, record a memory etc.
I never use 'record by fixture' but I will have a look.
re: Wipe all
Posted: 01 Dec 2005, 18:35
by jhld
I will try that when I get the chance. Today begins a busy weekend.
Posted: 05 Dec 2005, 00:28
I did have a quick play with 'rec by fixture', but I could not replicate.
If you can always repeat I would definitely email your showfile to Olie with instructions, since it may be traceable to a potential bug that I would rather not encounter!
