Pearl expert v9.1 lagg
Posted: 26 Aug 2015, 11:14
by turbojon
Yesterday I uppgraded from v 6.(?) to 9.1. Standard recovery.
Still running same showfile and programmed some new keyframe shapes.
It start to lagg when using shapes. Dmx output freez about 1-2 second and allso flashbuttons is not responding as fast as they where in v6.
It is no lagg when programming only when I am running the show whit all lights.
32x pixelmapped tribars 54ch per fixture
40x movinglights
20x rgb parcans
6x atomic
24ch dimmer
using artnet and standard dmx total 8 univers.
no lagg in v6. What can I do?
Re: Pearl expert v9.1 lagg
Posted: 17 Oct 2015, 01:37
by Adrasoy
I don't know if you already solved your problem, but I just had the same problem and I think I've found the solution.
When you go to the DMX settings, you can see a header Art-Net. Next to it a Gear symbol for the properties.
And then you can enable or disable some properties.
Enable the Always Broadcast ArtNet.
This solved the problem for me.
