I have a Pearl 2008 which up until now I've only really used for busked band shows. I now have to do a theatrical show so I'm looking at the theatre stack mode.
My problem is running a chase and movers at the same time, here's what I'm trying to achieve.....
I have a look setup, saved to a cue, all good....
next cue adds some movement to some movers, all good....
next cue starts a chase of different LED lights from a playback using a fade up autoload, not so good....
the chase starts but kills the movement already running, even if I fade up the playback manually the movement stops. The playback seems to kill the LTP channels of everything else, not even just the lights on the playback but everything.
What am I missing here, just don't seem to be able to run a chase and movement at the same time in theatre stack mode?
Cheers
Pearl 2008 theatre stack mode....
Users browsing this forum: No registered users and 5 guests
