v9 Cropped context window bug?
Posted: 24 Mar 2015, 18:43
by Clayton
See attached image.
Is there a way to scroll the context menu window when it gets cropped like this? I can never see the third row of buttons!
(Actually, this happens in v8.1, as well.)
Re: v9 Cropped context window bug?
Posted: 24 Mar 2015, 19:10
No, unfortunately not at the moment.
What is your display resolution? I am guessing something like 1280x700? Note that the recommended display resolution for Titan Mobile is 1280x800.
Posted: 24 Mar 2015, 19:19
by Clayton
This is on a Lenovo laptop with native 3200x1800 ("retina") resolution.
Everything else in Titan seems to display just fine, but that particular window always loses its 3rd row.
Posted: 24 Mar 2015, 19:53
Interesting. I can only think it's something to do with the high DPI of those screens and the way Windows is interpreting the scaling.
Might be useful to show a screenshot of the whole maximised window from a new show.
Does it help if you resize the window rather than maximise?
Posted: 24 Mar 2015, 20:05
by Clayton
Resizing / maximizing Titan has no effect on the context window button problem.
Here's a full screen capture (which will look super large on non-retina displays!)
Posted: 24 Mar 2015, 20:08
by Clayton
Here's a JPG resized to 1000px wide in case the previous image is unhelpful.
Posted: 24 Mar 2015, 20:14
Thanks. If you don't mind could you do one from a new show please? I'm interested to see how the fixtures and groups buttons layout. Resized is perfect.
Posted: 24 Mar 2015, 20:18
by Clayton
Sure thing. Here you go!
(I'd posted the Patch window, as it shows the problematic third row of buttons in the "Patch View - Patched Fixtures" context window).
Posted: 24 Mar 2015, 20:26
Great, thank you. I will raise this for investigation. In the meantime you may be able to workaround by changing the display resolution although I realise this is less than ideal.
Posted: 27 Apr 2015, 16:27
by Clayton
I just noticed that I see this exactly same problem when using a 3200x1800 display with Titan One. The buttons in the context window get cropped.
Do I need to submit a separate bug report?
Posted: 11 Aug 2015, 06:09
by jayreign
I'm having this problem too. did anybody ever find a fix for this ?
Posted: 11 Aug 2015, 17:04
by Clayton
Sadly, it has NOT been fixed in v9.1.
