Hi, my pearl 2010 has a usb port in the front for saving and loading data (normal)
but it also has a port for a usb cable in the back of the console
where is this used for ?
Pearl 2010 usb
Re: Pearl 2010 usb
Hi there
Can you pm me the serial number of your console, I can then guide you better
Re: Pearl 2010 usb
Hi!
I have the same questions, apart from the picture in this thread that is from a pearl clone due to the 3pin dmx...
but my sapphire 2000 does have the same usb jack?
I have tried searching the manual without luck
Re: Pearl 2010 usb
The port was put in so that it could be implemented later however no software was ever released that made use of that port.
Re: Pearl 2010 usb
Ric wrote:Hi there
Hello ,
The serial number of My Pearl 2010 is 8532.
I think it's the BORIS 3 Mother board.
what is the possible fonction for the famous rear usb connector?
Best regards
Re: Pearl 2010 usb
Gregory wrote:The port was put in so that it could be implemented later however no software was ever released that made use of that port.
This is still the case, the classic Pearl software is no longer being actively developed, the focus is now solely on the Titan platform.
Re: Pearl 2010 usb
Gregory wrote:Gregory wrote:The port was put in so that it could be implemented later however no software was ever released that made use of that port.
It's realy domage because i just bought a Pearl 2010 and it's a very expansive .
I hope connect the Pearl simulator like à synchronise console with the Pearl 2010!
The Pearl expert is Now out of m'y distributeur catalogue ...
Thanks for your answer.
Best regards
Users browsing this forum: No registered users and 118 guests
