azure pallete editing
Posted: 19 Apr 2005, 18:52
by Mikeyray
I was wondering if there ia a way to get rid of information in a palette without having to delete it and start again eg; gobo information in a colour pallete as I have 6 different fixture types in the same colour pallete and one of them has gobo info in it (I was sure i had specified the bank?)
cheers
Mikey
From the the manual
Posted: 21 Apr 2005, 01:37
by Slatham
• You can change the way the attributes are grouped when saving
palette entries by selecting the attribute button to change, then
pressing the Menu button below the Palette button, then option A
“Specify attributes for bankâ€. The buttons will light to show which
attributes are saved when that button is selected. You can press the
buttons to include or exclude attributes. Press Exit twice to finish.
From the azure manual
Azure Pallette editing
Posted: 22 Apr 2005, 15:52
by Mikeyray
yeah i realise that im talkin about editing palletes rather than creating them
Posted: 29 Apr 2005, 22:01
by Vincent
Didn't you ask the same question on the LightNetwork?
Anyway, as far as I recall correctly, you can achieve this as follows:
1. Select the fixtures the palette applies to
2. recall the palette with the attributes on "Dimmer"
3. Select the attribute you want to see removed (e.g. Gobo)
4. Press the "ON"-button of the wanted attribute until you see "OFF" on the screen
5. Record your palette again.
That shoud do the trick
