Now the key to system has gone, the normal way to system now is AVO key + Disk.
How do you do that in Titan Simulator?
Shift + D does not work for me, not even with the virtual panel hidden . I'm using a Dell Latitude laptop.
Thanks.
Titan Simulator
Re: Titan Simulator system key solved
Sorry, I have just answered my own question.
"Personally I really like the keyboard shortcuts fpr the Simulator. On your keyboard, press Shift-Alt-S, to access System Mode."
Re: Titan Simulator
You can hold down buttons in the simulator by right-clicking.
Re: Titan Simulator
Any idea how I might simulate pressing and holding a group so I can select random order from the softkeys? I'm trying to use simulator without a touchscreen
Re: Titan Simulator
The 'holding group button' doesn't work in simulator, but there are other ways:
- select the group
- press <Odd/Even> (or <All/Odd/Even>)
- click [Random Order]
There is also a macro 'Select Random Order'. If you need this frequently then you might copy this macro e.g. to the groups window. Then you only need to select the group and fire this macro, thus saving you one button press. Yay
- select the group
Re: Titan Simulator
icke_siegen wrote:The 'holding group button' doesn't work in simulator, but there are other ways:
- select the group
Cheers boss I knew I was being an idiot, that was driving me crazy, very much obliged
