V7 Issues
Posted: 21 Sep 2013, 12:10
by pbulder
Hi all,
I made a quelist for my atomics,
low-mid-high-burst-ramp up- etc.
with the key profile that the blue button was GO, and the Grey FLASH.
Since the update to V7 this doesn't work anymore, i can step through the quelist but only the first and the fourth que respond to the flash button.
the fader works on all que's though.
Made a New quelist for this, with a new Key profile. Problem remains
How is this possible.
Also i had a que with effects on my video, since the update the effects had changed.
for example: the que used to fire video layer 1 visual 23. with split effect.
Now it fires the same video, but with a different effect.
strongly thinking to go back to V6.1
is this possible and without any risk?
Re: V7 Issues
Posted: 21 Sep 2013, 12:34
Oh dear. Looks like the flash problem is an issue with tracking. If you turn it off then flash will work for all the cues.
It's hard to say about your video issue. What information is there when you view the cue?
