Layout editor.
Posted: 07 Jul 2013, 13:47
by stevelights
Hi, I'm trying to use Clay Paky Aleda 10, and 20 in extended mode with the pixel mapper. In the layout editor the Aleada fixture cells result to be all in straight lines.
Is there a way to reorganize the individual cells to correspond to the actual fixture layout, which is more of a spiral form?
Re: Layout editor.
Posted: 07 Jul 2013, 14:00
The cell layout is defined in the personality file. If you open it in Personality Builder you can adjust it yourself. If it's already patched easiest route is Patch/[Edit Fixtures]/[Edit Personality]/[<fixture>]. In Personality Builder expand the modes section on the left if not already and select the relevant mode to adjust. Then select the cells tab at the bottom right to open the cell layout. Drag and drop cells as required then save the personality.
Re: Layout editor.
Posted: 08 Jul 2013, 16:00
by Gregory
The personalities were updated to include the correct layout at the end of last year. It may be worth downloading and installing the latest version of the personality library from
http://personalities.avolites.com/. Note that you may need to delete your fixtures and patch them again to ensure that you are using the latest version of the personality.
Re: Layout editor.
Posted: 08 Jul 2013, 16:39
by stevelights
Thank you, that's fine, and thanks for the effort you put into the job to make easier for us lesser mortals.
