Recently I programmed my Tiger Tuch for a big danceparty.
I made three separatly cuelists, one for each type of fixture I had.
I could not find out how to wiew more than one cuelist at the time.
I had an external screen, with the idea that I would split it and wiew all the lists there, but the screen only showed the active one...
Is there anybody else having the same problem?
Best regards/ Micke!
Viewing more than cuelist
While on the subject of cuelists, I woulld really like to see a fix that would keep the selected and next cues visible at all times like it is on the little window on the main screen.Currently if you load the list and select first cue the cue 1 is at top of the screen. As the cue list proceeds to run the cursor bar goes down the screen but when it gets to the bottom you cannot see the upcoming cues without manually scrolling the window. Ideally the window would move automatically.
Although it is not quite the same the window should scroll so that the live cue is always in view along with the one immediately after it. For this to work please ensure that no cues are highlighted in blue as this indicates that they are selected for editing so the window will not scroll. The simplest way to deselect all the cues is to select one of the legends (which will take you into the Set Legend menu) then press Exit.
