BCF2000
Posted: 22 May 2012, 06:39
by dim_111
Hi!
I successfully connect BCF2000 to Titan mobile, but I want to BCF2000 send values on faders/encoders every time I change preset.
I programmed faders/encoders/knobs on each presets to equal midi channels.
Then I set faders on different presets to different positions.
When I change preset faders set to pre-programmed positions, but BCF200 send nothing to titan mobile.....
Anybody know the solution?
Thank you!
Posted: 22 May 2012, 16:56
by icke_siegen
I fear there is no real solution for you. You can call Snapshot-Send after each preset change (EDIT + <); see BCF 2000 manual section 4.6. But you have to do this manually after each preset change; no way of automating this (and of course, since the BCF is sending no data, there is no point in looking into the Titan Mobile for a solution)
Posted: 22 May 2012, 17:23
by dim_111
Thank you!
This is better then nothing....
Hope Behringer will include this issue to future firmware update....
