Page 1 of 2
Martin MAC Aura and Titan V5, how-to
Posted: 09 Jan 2012, 19:54
by frontal
Anyone working with the Martin MAC Aura and Titan V5?
I am wondering how you guys are patching this fixture, so that its possible to fully utilize the Aura-effects.
Ref the instructions from Martin, this fixture should be patched in a special way to do this.
Regards,
Kurt
Norway
Posted: 09 Jan 2012, 21:00
You need to patch the 25 DMX mode to access effects.
In Martin speak this is written as a 'multi-part' fixture. When unfolded, cell 1 is the 'beam' part and cell2 is the 'aura' part.
Effects are available in cell 1 and from the master (or folded) fixture.
Effects are chosen using the attributes 'Effect 1' and 'Effect 2'. 'Effect 1 Speed' and 'Effect 2 Speed' control variables for the respective effect chosen, although not only speed.
When the functions from attribute 'Effect Sync' are of the 'No Sync' type then the two effects can be controlled independently. When set to a 'Sync' type only Effect 1 Speed has any affect.
I noticed that they mention 'Certain FX require Aura intensity to be
above 0% to be visible', but I couldn't see any further information.
Posted: 09 Jan 2012, 23:58
by frontal
Thanks for replying
What do you mean by this:
"You need to patch the 25 DMX mode to access effects"
Could you explain the steps you are doing? I am kinda a newbie on Avolites as well, so if you dont mind, please just take it step by step.
Regards,
Kurt
Posted: 10 Jan 2012, 07:52
- Patch
- [Fixtures]
- [Martin]
- [MAC Aura]
- [25 DMX, 16 bit]
- Change Line/DMX address as required
- Select a handle to patch to
Posted: 10 Jan 2012, 08:22
by frontal
Yeah, already done that
, but isnt it necessary to "split" the fixture so that its possible to controll the Led-section and the Aura-section independantly?
Posted: 10 Jan 2012, 09:00
Press Unfold and then select the fixture. You will then see three fixtures - a master (exactly the same as when it was 'folded') and cell 1 and 2.
Cell 1 is what Martin calls the 'beam' part. Cell 2 is the 'aura' part. Select these to control the parts independently.
Press Unfold/[Exit] (or Unfold twice) to return to normal fixture selection.
It is a known usability issue that you can only unfold one fixture at a time making editing multiple fixtures awkward. At the moment the solution is to make groups or assign handles of the cells. See
here for more details.
Posted: 10 Jan 2012, 09:13
by frontal
Excellent stuff! So I can store the individual parts of the fixtures, cells, to each handle as well then?
Posted: 10 Jan 2012, 10:34
Yes
Posted: 10 Jan 2012, 12:55
by frontal
Thank you very much
Posted: 12 May 2012, 14:07
by peter.rodda
is it possible to "unfold" a robe robin 600LED wash to get access to the 3 cells and group them? If I push unfold and then a 600 fixture, then I just get a window with 1 fixture?
Posted: 12 May 2012, 14:08
by peter.rodda
Posted: 12 May 2012, 14:25
by icke_siegen
Depends from the mode. Mode 1 and 5: yes. The others: no.
And of course an updates library is required (last change was in december last year).
Posted: 19 Jun 2012, 09:16
by f.antoci
is it possible unfold more than one fixture at same time?
And i notice that is not possible change the fixtures order if i made a cue with unfold fixtures (e.g. with all cell1 I see the order but I can't change, the button is not active)...I did something wrong?
Posted: 19 Jun 2012, 09:34
by icke_siegen
Unfortunately, in v5 you can only unfold one fixture at a time. Nick has given quite a lot of ways to work with this - and it will be improved in v6.
See
http://www.avolitesshop.co.uk/phpBB3/vi ... php?t=2087 and
http://www.avolitesshop.co.uk/phpBB3/vi ... php?t=2077
Don't know about that fixture order thing.
Posted: 19 Jun 2012, 19:24
by f.antoci
thanks for replying
let me know if there will be more info on fixture order
thanks again
