Titan Simlator
Posted: 25 Nov 2011, 12:37
by Adamastor
I have instaled titan simulator in 2 diferents computers and in both appened the same problem, first time runs well, after that the program don't start, it freeze in the loading part
What could it be?
Posted: 25 Nov 2011, 12:50
by icke_siegen
Maybe the services are not terminated correctly after closing the program. Check taskmanager for running service named 'USBExpertService' and 'ActiceFixtureService'
Posted: 20 Dec 2011, 15:07
by Filipe
hi guys
im having the same problem, i can't open my titan simulator, it just stays in the "Starting Titan..." and stays there.
any feedback from this?
thanks so much
Posted: 20 Dec 2011, 15:49
by icke_siegen
which version of simulator are you running? which version of windows?
- did you already activate it (Simulator)? Maybe the window is sitting in the background, waiting for your input - toggle with Alt+Tab
- see the previous answer: maybe the services are not terminated correctly before starting Simulator again. So: was it running before?
- find and rename the file SHUTDOWN.d4b (in User\AppData\Roaming\Avolites\Titan)
and please, in order to help improving the software, write what you do/did, and maybe the answer to the questions above
Posted: 21 Dec 2011, 12:00
by Filipe
Thanks so much icke_siegen
- i already activate the simulator and worked for the first time that i open it.
- i restarted my computer several times, and opened only the simulator.
- when i start the tiger touch, it opens the Virtual panel but the simulator stays in the "starting titan" window and do not open.
- i openend the titan simulator for the first time, it worked, and i load the demo show and was the last recorded. it seems titan load that show everytime i turn on the simulator but only in the virtual panel, the simulator stands in a freeze mode as i describe above.
theres any way to load a blank show to see what happen?
im using titan in a win xp 32 bits sp3, i have another computer with the same operating system and works just fine.
thanks for all the help
F
Posted: 21 Dec 2011, 12:17
by icke_siegen
sounds like the last point in my list:
on my XP box the path is
C:\Documents and Settings\my_name\Application Data\Avolites\Titan
Posted: 21 Dec 2011, 16:24
by Filipe
Hi again
problem solved !
i reinstalled the simulator and erase the last show
now it works just fine, maybe was an error left in the last saved show
Thanks !
