Hello everybody,
since I update my Pearl Expert and my Titan Mobile to Version 5, I have the following Problem:
When I set a Fade Time for a Playback, I can´t use the Flash Button. When I rise the Fader, the Cue fade in programmed Time to Target Position. When I use the Flash Button, the Fade Time will be ignored - the Beam´s snap to Target Position without fading. When I release the Button befor the Time is over, the Beam´s snap back a bit.
Means: Fade Time 4 sec. --> bush Flash Button Beam´s snap to Target --> release the Button after 2 sec. , the Beam´s snap back to 50 %
To anyone else have this Problem
GR, Elli
Flash Problem with Titan V5
- john rogers
There are two workarounds in the meantime. One is to make a 2 step cuelist, step 1 @ 100; step 2 @ 0% with a fade out time on step 2.
The other way is to set the grey key to latch, then press once for full and a second time for your fade out.
As Nick says we're aware of this.
I've having problems changing the blue executors to flash in version 5. In the show file they were set to a flash key profile. After the update to V5 they became latch (even with the same key profile). I tried editing the key profile and remaking all the buttons flash, but it still latches. I also tried a brand new key profile with every key set to flash, but it still latches. Is this a common problem? I have not tried with a fresh show file... but I need it in this show file.
