Titan Mobile - Cue Only Recording & Release?
Posted: 22 Aug 2011, 21:43
I'm fairly new to Titan Mobile, with primarily a theatrical programming background. I was hoping someone could help me find a solution to these to common "theatre" programming questions.
1) Is there a way to record "cue only" when in a cue list and hence not have it track through the rest of the list?
2) Is there a "release" feature, that simply releases the last change that you've made in the programmer? For example you select a fixture, start to move it and realize that it's the wrong one or you don't like the look, instead of hitting "clear" and loosing all of the changes, the fixture would be "released" to it's last state and you can continue building your look.
Thanks!
Thanks!
