Rotate fixtures by 90 Degrees
Posted: 17 Aug 2011, 18:53
Is it possible to rotate all a fixtures programming by 90 Degrees?
Like it is possible to flip the tilt in fixture options if you get to a site you have pre-programmed and the light has been rigged in the opposite direction (LCD/Cables/Arrow to the back instead of to the front, or vice versa. It would be nice to add/rotate the pan the fixture by 90/180/270 Degrees if the light was rigged LCD/Cable/Arrow to the side instead of front or back.
e.g. Robe fixtures home to the side if LCD is to the front or back, so I always rig them with LCD to Stage Right if I am there for load-in… but some companies rig them to the front or back, and then it becomes a long process to add or subtract 16.6 degrees from each position pallet. Recently it took almost two hours with a rig with 32 fixtures and 16 position pallets to update each (that’s 32x16=512 position updates even using pallets).
Is this already possible, or is it on the wish list?
