Hello.
In Pearl 2008 does not display the patch text.
Use the latest version of libraries.
Thanks.
Patch text in Pearl 2008
Hi Emma, thanks for responding.
In Pearl 2000/2004, when a device pach, just before you press the handle to patch, this text is displayed on the LCD:
Mac301w Standard
16bit
Encoder Banks
Wheel A Wheel B
1 Dimmer --
2 -- Shutter
3 Tilt Pan
4 Colour CTC
5 Zoom --
6 -- --
7 -- --
8 P/TSpeed EffSpeed
9 -- Blue
10 Red Green
14 PresColo --
20 Control Blackout
In Pearl 2008 is not shown.
Thanks.
Mac301w Standard
16bit
Encoder Banks
Wheel A Wheel B
1 Dimmer --
2 -- Shutter
3 Tilt Pan
4 Colour CTC
5 Zoom --
6 -- --
7 -- --
8 P/TSpeed EffSpeed
9 -- Blue
10 Red Green
14 PresColo --
20 Control Blackout
Thanks.
- john rogers
This file required a technical update and was regenerated from our Personality Builder software. This has reduced the patch text screen to
The reason the wheel information is no longer displayed here is to aid the speed of creation of R20 files for classic Pearl.
Martin Mac 301 wash
Standard, 16bit
Thanks John.
Edit my libraries, and put in the text field:
TEXT
Vari-Lite VL3000
Spot - 28 Channels
Encoder Banks
Wheel A Wheel B
1 Dimmer --
2 Iris Shutter
3 Tilt Pan
4 Colour CTO
5 Zoom Focus
6 Gobo1 Gobo1Rot
7 Gobo2 Gobo2Rot
8 Gobo3 Gobo3Rot
9 -- Yellow
10 Cyan Magenta
11 Control --
12 P/TSpeedColorTime
13 BeamTimGoboTime
www.arcoirislight.com
END
But not shown.[code][/code]
TEXT
Vari-Lite VL3000
Spot - 28 Channels
Encoder Banks
Wheel A Wheel B
1 Dimmer --
2 Iris Shutter
3 Tilt Pan
4 Colour CTO
5 Zoom Focus
6 Gobo1 Gobo1Rot
7 Gobo2 Gobo2Rot
8 Gobo3 Gobo3Rot
9 -- Yellow
10 Cyan Magenta
11 Control --
13 BeamTimGoboTime
END
This has moved to another location:
- patch as usual (only the DEVICEADDRESS section of the personality will be displayed)
- exit the patch menu
- hit VIEW
- hit [B] Fixture Attributes - this will display the actual Wheel mapping
- hit the select key of the fixture
Note the fixture is in the programmer now. Hit Clear to clear, or hit View to blank the display.
maybe someone else could say whether the TEXT section is displayed at all (Heck, usually no need for it, since the real wheel mapping is displayed now)
Sebastian
- hit VIEW
Sebastian
Users browsing this forum: No registered users and 7 guests
