CITP ON TITAN 4
Posted: 16 Feb 2011, 21:46
by litefish
HI
I HAVE A NEW TITAN MOBILE
I HAVE A ARKAOS MM PRO 2.2 PATCHED
ALL IS RUNNING WELL BUT NO THUMBS IN
THE ATTRIBUTE CONTROL
IS CITP WORKING IN TITAN 4 WITH ARKAOS
IF SO WHAT I MISSING
THANKS LITEFISH
Posted: 16 Feb 2011, 22:56
Do you have it patched as an active fixture?
citp ON TITAN 4
Posted: 17 Feb 2011, 03:09
by litefish
hi
NO I DO NOT
WHEN I HIT ACTIVE FIXTURE WHEN PATCHING
NOTHING COMES TO PATCH(NO FIXTURES)
PLEASE POINT ME IN THE DIRECTION
THANKS LITEFISH
Posted: 17 Feb 2011, 10:53
First you need to make an ethernet connection between the console and the machine running Arkaos. This can either be direct or via a switch (router).
The two must be on the same IP range. For example if both are connected to a router with gateway 192.168.1.1 then Arkaos can be 192.168.1.2 and console can be 192.168.1.3. You can set the IP address in the console from the System menu.
Next you need to add an Artnet node to one of the Expert outputs. Go to System/[DMX Settings] and open the Artnet section on the left-hand side. The Arkaos machine should be there as an option. Add this to the appropriate output on the right.
Now go back to Program/Patch/[Active Fixture]. Arkaos should appear in the softkey options. Choose this and then continue to patch as normal.
For more help on Networking and DMX Settings see the manual
Posted: 17 Feb 2011, 20:30
by litefish
Hi
So I just need to patch after the network is connected
Not before as I did
That's easy
Thanks litefish
