Pearl Expert + Elo Touch Screen
Posted: 11 Nov 2010, 18:52
by Andygwk
Hi
I have an elo usb touch screen and was wondering if its possible to set it up on the pearl expert running titan. And if so how would i go about doing this.
Andy
Posted: 12 Nov 2010, 11:54
by EmmaThompson
Hey Andy,
Yes, you can use touch screens with any Titan console. You will need to install the drivers on the console, then calibrate the touch screen.
Posted: 13 Nov 2010, 02:15
by ricws
Hi Emma
Has Avo's position on touch screens changed then? Last I knew you discouraged the use of external touch screens because of potential problems with the drivers.
Posted: 15 Nov 2010, 10:26
by Olie
I recently had a customer trying to install an Elo touch screen and they where unable to get it working. So not all touch screens will work.
You must have an Expert with a Touch wing before you can install an additional touch monitor. You can then choose one of two models.
NEC MultiSync LCD195VXM+
iiyama ProLite T1731SR
Others may work but could cause your console to become unstable.
