led parcans
Posted: 11 Oct 2010, 00:11
by zahoorjury
hi all,
is anybody know how to create a RGB LED Parcan personality using Raul's software.
Posted: 11 Oct 2010, 13:08
by EmmaThompson
Avolites personalities can be made using the Avolites Personality Builder software. However for RGB Parcans, you can always use the generic RGB personality found under manufacturer 'Generic'
Posted: 12 Oct 2010, 12:32
by zahoorjury
hi, i also just want to know theory. i mean that when we make a personlaty for a moving head or scanner, we have a colour & gobo wheels. so any realated shape can work with this format, But,
how can we asign RGB channels. do these colours could asign as a CMY buttons in Azure 2000 ?.
do the shapes work with our own created personalities ?. as we have three or four colours in different channels.
( i even not try these practicaly yet )
Posted: 12 Oct 2010, 13:08
With .r20 files it is often easiest to look at in notepad or similar text editor. The file format and how to create personalities this way is explained in the manual.
I recommend looking at an existing CMY and RGB personality and comparing. I find this the best way to learn and understand. Note that you can view this from the online library by clicking on 'view source'.
Within the 'DMX' section, the first two columns define which buttons select these attributes. The 7th column defines the attribute type which is how it knows what shapes apply.
RGB is represented by TUV respectively (this is not documented). CMY colour mixing shapes work on BCD attribute types and RGB shapes work on TUV types.
If there are four colours (ie. RGBA or RGBW) then usually the amber or white channel is placed where a traditional 'fixed' colour wheel might be and given a type 0 (uncategorised). The extra channel is not used in shapes.
BCD & TUV
Posted: 16 Nov 2010, 23:25
by zahoorjury
hi nic, what do you mean by , TUV & BCD ?.
Posted: 17 Nov 2010, 00:45
Copy of relevant section from .r20 file:
; DMX channel description
;<snip>
; 8. Attribute type (A=Color Wheel1, B=Cyan, C=Magenta, D=Yellow,
; E=Pan, F=Tilt, G=Iris, H=Dimmer, I=Gobo1, J=Gobo2, K=Gobo1_Rotate,
; L=Focus, M=Gobo2_Rotate, N=Color Wheel2, O=Shutter, P=Prism, Q=Zoom,
; R=Effect_Rotate, S=Frost, T=Red, U=Green, V=Blue, 0=uncategorised)
;Example CMY section:
10 1 L 3 100 1N B 1 "Cyan" 0 0 255
10 61 L 4 100 1N C 1 "Magenta" 0 0 255
9 61 L 5 100 1N D 1 "Yellow" 0 255 0Example RGB version of the above:
10 1 L 3 100 1N T 1 "Cyan" 0 0 255
10 61 L 4 100 1N U 1 "Magenta" 0 0 255
9 61 L 5 100 1N V 1 "Yellow" 0 255 0
