Remove Fixtures from a Memory - Pearl 2004
Posted: 03 Nov 2009, 00:15
by S Preston
Hey all.... I think I am doing something wrong.... I am trying to remove 2 fixtures from a memory using OFF. I activate the memory, select the fixtures, press OFF, press softkey A, press MEMORY, press the desired SWOP button for the memory I am wanting to alter.
Nothing happens OR the entire memory goes out.
Am I missing something? Any help would be appreicated....
Posted: 03 Nov 2009, 01:34
Are you getting the option to merge/replace?
Posted: 03 Nov 2009, 02:50
by S Preston
No, I am not getting the merge/replace option
Posted: 03 Nov 2009, 09:19
by Olie
What version of software are you running?
Posted: 03 Nov 2009, 16:27
by S Preston
I am trying to get this software version... I am in Las Vegas and the console is in Detroit. So am I to assumethat the correct procedure is being used and it may be a software issue?
Posted: 03 Nov 2009, 18:40
by S Preston
Just got the word... the console is running software V 1.2.2.
Posted: 03 Nov 2009, 20:01
by S Preston
Got it.... Spoke with Steve in the Tenn office and he got us set. It had to do with the shape generator.... all is good. Thanks for the help!
Posted: 03 Nov 2009, 21:39
If you have time it would be useful to post your solution to the problem so that others can benefit when searching in the future.
