Azure 2000
Posted: 19 Mar 2009, 04:21
by thistle2005uk
Hiall,
is there a way to quickly remove a patched fixture?
Thanks in advance, Paul
Posted: 19 Mar 2009, 12:22
Patch/Delete?
Azure 2000
Posted: 19 Mar 2009, 12:56
by thistle2005uk
sorry mate! should have said this is for the Azure 2000. not the Pearl. the desk doesn't have a delete button!!!!! Argghh
Posted: 19 Mar 2009, 13:13
Can you use 'cut'?
Posted: 19 Mar 2009, 13:41
by thistle2005uk
No. When I select that it does give display several options including fixture, but it only allows me to select option <A>DMX Channels or exit! A glitch possibly. When I try <A> i can delete the channels but this just parks the fixture.
Posted: 20 Mar 2009, 01:37
by theisbr
I use an Azure Shadow2004, and to delete fixtures or dimmers on that console press "CUT" and then press the desired fixture or dimmer select button (the 1-20 buttons) on the appropriate dimmer or fixture page. You need to be in a normal page, not the patch page.
This should work if you want to delete a group too.
Hope this helps.
Brian
Posted: 20 Mar 2009, 18:46
by thistle2005uk
Cheers Mate, It works a treat and so Simple too. I'm sure it doesn't say how to do it in the manual.
Paul
Posted: 20 Mar 2009, 19:00
by theisbr
I did not find it in the manual. I actually found it by accident.
Glad to help.
Posted: 26 Feb 2010, 06:49
by muvment
After about an hour of trying, i discovered this thread. Saved!
What other undocumented features do you guys know about on the azure?
