Hiall,
is there a way to quickly remove a patched fixture?
Thanks in advance, Paul
Azure 2000
Azure 2000
sorry mate! should have said this is for the Azure 2000. not the Pearl. the desk doesn't have a delete button!!!!! Argghh
I use an Azure Shadow2004, and to delete fixtures or dimmers on that console press "CUT" and then press the desired fixture or dimmer select button (the 1-20 buttons) on the appropriate dimmer or fixture page. You need to be in a normal page, not the patch page.
This should work if you want to delete a group too.
Hope this helps.
Brian
Hope this helps.
Brian
