building fixtures..
Posted: 16 Oct 2008, 09:49
when will building fixtures be doeble in the diamond4 cosoles?
One of few things I really do miss when using my D4.
; The Clay Paky Alpha Spot HPE Personality for the Diamond II |
; History :- |
; Revision | Date | By | Description |
; 1.0 | 03-04-06 | Ed | Created from Alpha Spot HPE |
; | 04-04-06 | Ed | Checked |
DEVICE=CPA12H16M1 ; Device Name (upto 11 chars after '='
DEVICE23=28 channels ; 22 chars after '='
; extra information for softkey prompt lines 2&3
; a total of 22 chars, split into 2 lines of 11
; Device information
; __ Number of lines of DMX info.
; | __ Number of lines of wheel info
HSTART 1 28 1b05 450 252 ff 0 6 28 24
; | | | | | | | |__ Line number for flash button DMX info
; | | | | | | | from DMX definition (1..x)
; | | | | | | |__ Button release value
; | | | | | |__ Button ON value (ff means use swop/add fader)
; | | | | |__ The TILT arc in Degrees
; | | | |__ The Pan arc in degrees
; | | |__ Date in PC format (1b05==5/08/93)
; | |__ Number of DMX slots used
; |__ Patch direction (1-backward, 0 forward, (3 for moving head, 1 for Moving Mirror))
TEXTSTART ; Upto 21 lines of 28 characters (use the template)
CLAY PAKY ;
Alpha Spot 1200 HPE ;
PERSONALITY ;
16b ;
TEXTEND
; For the Attribute Dictionary refer to file 'dict.per'
; DMX information
; No unused lines allowed between keyword 'DSTART' and last DMX definition
DSTART ; DMX defintion
1 2 0 0 8 0 ; CYAN
2 2 0 0 7 0 ; MAGENTA
3 2 0 0 9 0 ; YELLOW
4 2 0 0 149 0 ; CTO
5 2 40 0 4 0 ; COLOR
6 2 40 0 24 0 ; SHUTTER
7 1 0 0 0 0 ; DIMMER
8 2 0 0 15 0 ; IRIS
9 2 40 0 11 0 ; GOBO1
10 2 40 0 36 0 ; GOBO2
11 2 20 0 153 0 ; GOBO2ROT
27 0 0 0 153 0 ; GOBO2FINE
12 2 40 0 37 0 ; GOBO3
13 2 20 0 154 0 ; GOBO3ROT
28 0 0 0 154 0 ; GOBO3FINE
14 2 40 0 51 0 ; EFFECT
15 2 0 0 41 0 ; EFFECTROT
16 2 40 0 16 0 ; PRISM
17 2 0 0 78 0 ; PRISMROT
18 2 0 0 40 0 ; FROST
19 2 0 0 12 0 ; FOCUS
20 2 0 0 43 0 ; ZOOM
21 2 20 0 13 0 ; PAN
25 0 0 0 13 0 ; PANFINE
22 2 20 0 14 0 ; TILT
26 0 0 0 14 0 ; TILTFINE
23 2 40 0 80 0 ; RESET
24 2 40 0 52 0 ; LAMP CONTROL
;| | | | | |__ Spare (always 0 for now)
;| | | | |__ Attribute name (See list above)
;| | | |__ Curve (0 means no curve otherwise curve number)
;| | |__ Flags (7=inverted, 6=instant, 5=16-bit)
;| |__ Channel type (1=HTP, 2=LTP, 0=Dummy(for 16-bit defines)
;|__ DMX offset (1..255, 0 means DIMMER will be patched seperately)
; WHEEL information
; No unused lines allowed between keyword 'WSTART' and last DMX definition
WSTART
8 ffff ffff 1 8 0 10 0 1 0 1 0 0 0 0 0 ; 1. CYAN
8 ffff ffff 1 7 0 11 0 1 1 2 0 0 0 0 0 ; 2. MAGENTA
8 ffff ffff 1 9 0 12 0 1 2 3 0 0 0 0 0 ; 3. YELLOW
8 ffff 0 1 149 0 15 0 1 3 4 0 0 0 0 0 ; 4. CTO
8 ffff 0 1 4 0 9 0 1 4 5 0 0 0 0 0 ; 5. COLOR
8 ffff ffff 1 24 0 1 0 1 5 6 0 0 0 0 0 ; 6. SHUTTER
8 ffff ffff 4 0 0 8 0 1 6 7 0 0 0 0 0 ; 7. DIMMER
8 ffff 0 1 15 0 2 0 1 7 8 0 0 0 0 0 ; 8. IRIS
8 ffff 0 1 11 0 23 0 1 8 9 0 0 0 0 0 ; 9. GOBO1
8 ffff 0 1 36 0 17 0 1 9 10 0 0 0 0 0 ; 10. GOBO2
4 ffff 0 1 153 1 19 0 1 10 11 0 0 0 0 0 ; 11. GOBO2ROT
8 ffff 0 1 37 0 18 0 1 12 13 0 0 0 0 0 ; 12. GOBO3
4 ffff 0 1 154 1 20 0 1 13 14 0 0 0 0 0 ; 13. GOBO3ROT
8 ffff 0 1 51 0 25 0 1 15 16 0 0 0 0 0 ; 14. EFFECT
8 ffff 0 1 41 0 27 0 1 16 17 0 0 0 0 0 ; 15. EFFECTROT
8 ffff 0 1 16 0 26 0 1 17 18 0 0 0 0 0 ; 16. PRISM
8 ffff 0 1 78 0 28 0 1 18 19 0 0 0 0 0 ; 17. PRISMROT
8 ffff 0 1 40 0 31 0 1 19 20 0 0 0 0 0 ; 18. FROST
8 ffff 8080 1 12 0 3 0 1 20 21 0 0 0 0 0 ; 19. FOCUS
8 ffff 0 1 43 0 4 0 1 21 22 0 0 0 0 0 ; 20. ZOOM
4 ffff 8080 3 13 1 5 0 1 22 23 0 0 0 0 0 ; 21. PAN
4 ffff 8080 3 14 1 6 0 1 24 25 0 0 0 0 0 ; 22. TILT
8 ffff 0 1 80 0 41 0 1 26 27 0 0 0 0 0 ; 21. RESET
8 ffff 0 1 52 0 42 0 1 27 28 0 0 0 0 0 ; 22. LAMP CONTROL
;| | | | | | | | | | | | | | | |__ List of Table channels as
;| | | | | | | | | | |_______________ line numbers from DMX def.
;| | | | | | | | | | 0 means unused channel
;| | | | | | | | | |__ DMX line (minus 1) pertainig to this wheel
;| | | | | | | | |__ Number of chanels under control OR Table width
;| | | | | | | |__ Table type (Attribute number) 0 means NOT a table
;| | | | | | |__ Wheel number (1..8 on bank1, 9..16 on bank2 et cetera)
;| | | | | |__ 0 for 8 bits, 1 for 16 bits
;| | | | |__ Attribute name from above list (0..MAX)
;| | | |__ Wheel type (1-offset, 2-Table, 3-Pan/Tilt, 4-Dimmer)
;| | |__ Default value (left shifted as necessary)
;| |__ AND mask, where more than wheel controls same DMX slot
;|_ Wheel multiplication =16-(bits used)
;eg. for 8 bit channels it is 8, for 12 bit channels it is 4
; TABLES
; Each Table is enclosed by the keywords "TSTART" and "*** TEND ***"
; The legend is 16 chars long
; The correct number of values must be supplied (8-bits) with spaces in
; between
MACRO "Lamp On" 1 24
32 DA
0 0
MEND
MACRO "Lamp Off" 2 24
32 3F
0 0
MEND
MACRO "Reset" 3 23
32 C0
0 0
MEND
; History :- |
; 1.0 | 04-04-06 | Ed | Created from extn version |
DEVICE=CPA12HStM1 ; Device Name (upto 11 chars after '='
DEVICE23=24 channels ; 22 chars after '='
HSTART 1 24 1b05 450 252 ff 0 6 24 24
CLAY PAKY ;
PERSONALITY ;
std ;
TEXTEND
; DMX information
1 2 0 0 8 0 ; CYAN
4 2 0 0 149 0 ; CTO
8 2 0 0 15 0 ; IRIS
9 2 40 0 37 0 ; GOBO3
10 2 40 0 11 0 ; GOBO1
11 2 40 0 153 0 ; GOBO1ROT
12 2 40 0 36 0 ; GOBO2
13 2 40 0 154 0 ; GOBO2ROT
14 2 40 0 51 0 ; GRAPHICSDISC
15 2 20 0 41 0 ; GRAPHICDISCROT
16 2 20 0 16 0 ; PRISM
17 2 40 0 78 0 ; PRISMROT
18 2 40 0 40 0 ; FROST
19 2 40 0 12 0 ; FOCUS
21 2 40 0 13 0 ; PAN
22 2 40 0 14 0 ; TILT
; WHEEL information
WSTART
8 ffff 0 1 37 0 23 0 1 8 9 0 0 0 0 0 ; 9. GOBO3
8 ffff 0 1 11 0 17 0 1 9 10 0 0 0 0 0 ; 10.GOBO1
8 ffff 0 1 153 0 18 0 1 10 11 0 0 0 0 0 ; 11. GOBO1ROT
8 ffff 0 1 36 0 19 0 1 11 12 0 0 0 0 0 ; 12. GOBO2
8 ffff 0 1 154 0 20 0 1 12 13 0 0 0 0 0 ; 13. GOBO2ROT
8 ffff 0 1 51 0 27 0 1 13 14 0 0 0 0 0 ; 14. GRAPHICSDISC
8 ffff 0 1 41 0 28 0 1 14 15 0 0 0 0 0 ; 15. GRAPHICSDISCROT
8 ffff 0 1 16 0 25 0 1 15 16 0 0 0 0 0 ; 16. PRISM
8 ffff 0 1 78 0 26 0 1 16 17 0 0 0 0 0 ; 17. PRISMROT
8 ffff 0 1 40 0 31 0 1 17 18 0 0 0 0 0 ; 18. FROST
8 ffff 8080 1 12 0 3 0 1 18 19 0 0 0 0 0 ; 19. FOCUS
8 ffff 0 1 43 0 4 0 1 19 20 0 0 0 0 0 ; 20. ZOOM
8 ffff 8080 3 13 0 5 0 1 20 21 0 0 0 0 0 ; 21. PAN
8 ffff 8080 3 14 0 6 0 1 21 22 0 0 0 0 0 ; 22. TILT
8 ffff 0 1 80 0 41 0 1 22 23 0 0 0 0 0 ; 23. RESET
8 ffff 0 1 52 0 42 0 1 23 24 0 0 0 0 0 ; 24. LAMP CONTROL
; TABLES
; between
;--------------------------------------------------------------------Code: Select all
; Clay Paky Alpha Profile 1500 Extended,personality for the Diamond II |
; History :- |
; 1.0 | 27-11-08 | David Hunt| Created |
; | 27-11-08 | David Hunt| Checked |
; | 02-12-08 | J.Moreton | Checked |
DEVICE=CP_AP1200M9 ; Device Name (upto 11 chars) must be enclosed in single
DEVICE23=Extended ; 22 chars after '='
HSTART 3 28 1b05 0 0 ff 0 8 28 28
; |__ Patch direction (1-backward, 2 forward)
Clay Paky ;
Alpha Profile ;
1200 ;
Extende9 ;
28 DMX 8 bit ;
PERSONALITY ;
TEXTEND
; DMX information
DSTART ; DMX Picture
1 2 0 0 8 0 ; Cyan
2 2 0 0 7 0 ; Magenta
3 2 0 0 9 0 ; Yellow
4 2 0 0 149 0 ; CTO
5 2 0 0 4 0 ; Colour
6 2 40 0 24 0 ; Shutter
7 1 0 0 0 0 ; Dimmer
8 2 0 0 15 0 ; Iris
9 2 40 0 36 0 ; Gobo 1
10 2 40 0 37 0 ; Gobo 2
11 2 20 0 99 0 ; Gobo 2 Rot
12 0 0 0 0 0 ; Gobo 2 Rot Low
13 2 0 0 163 0 ; Blade Up 1
14 2 0 0 164 0 ; Blade Up 2
15 2 0 0 165 0 ; Blade Dw 1
16 2 0 0 166 0 ; Blade Dw 2
17 2 0 0 167 0 ; Blade Rg 1
18 2 0 0 168 0 ; Blade Rg 2
19 2 0 0 169 0 ; Blade Lf 1
20 2 0 0 170 0 ; Blade Lf 2
21 2 0 0 144 0 ; Framing Rot
22 2 0 0 51 0 ; Effect
23 2 0 0 41 0 ; Effect Rot
24 2 0 0 12 0 ; Focus
25 2 0 0 43 0 ; Zoom
26 2 20 0 13 0 ; Pan
27 0 0 0 0 0 ; Pan Low
28 2 20 0 14 0 ; Tilt
29 0 0 0 0 0 ; Tilt Low
30 2 0 0 80 0 ; Reset
31 2 40 0 52 0 ; Control
;| | |__ Flags (7=inverted, 40=instant, 20=16-bit)
; WHEEL information
WSTART
8 ffff 0 1 8 0 9 0 1 0 1 0 0 0 0 0 ; 1. Cyan
8 ffff 0 1 7 0 10 0 1 1 2 0 0 0 0 0 ; 2. Magenta
8 ffff 0 1 9 0 11 0 1 2 3 0 0 0 0 0 ; 3. Yellow
8 ffff 0 1 149 0 12 0 1 3 4 0 0 0 0 0 ; 4. CTO
8 ffff 0 1 4 0 15 0 1 4 5 0 0 0 0 0 ; 5. Colour
8 ffff 6969 1 24 0 1 0 1 5 6 0 0 0 0 0 ; 6. Shutter
8 ffff ffff 4 0 0 8 0 1 6 7 0 0 0 0 0 ; 7. Dimmer
8 ffff 8383 1 15 0 33 0 1 7 8 0 0 0 0 0 ; 8. Iris
8 ffff 0 1 36 0 17 0 1 8 9 0 0 0 0 0 ; 9. Gobo 1
8 ffff 0 1 37 0 18 0 1 9 10 0 0 0 0 0 ;10. Gobo 2
4 ffff 0 1 99 1 19 0 2 10 11 0 0 0 0 0 ;11. Gobo 2 Rot
8 ffff 0 1 163 0 34 0 1 12 13 0 0 0 0 0 ;12. Blade 1 Up
8 ffff 0 1 164 0 35 0 1 13 14 0 0 0 0 0 ;13. Blade 2 Up
8 ffff 0 1 165 0 36 0 1 14 15 0 0 0 0 0 ;14. Blade 1 Dw
8 ffff 0 1 166 0 37 0 1 15 16 0 0 0 0 0 ;15. Blade 2 Dw
8 ffff 0 1 167 0 38 0 1 16 17 0 0 0 0 0 ;16. Blade 1 Rg
8 ffff 0 1 168 0 39 0 1 17 18 0 0 0 0 0 ;17. Blade 2 Rg
8 ffff 0 1 169 0 40 0 1 18 19 0 0 0 0 0 ;18. Blade 1 Lf
8 ffff 0 1 170 0 43 0 1 19 20 0 0 0 0 0 ;19. Blade 2 Lf
8 ffff 0 1 144 0 44 0 1 20 21 0 0 0 0 0 ;20. Framing Rot
8 ffff 0 1 51 0 25 0 1 15 16 0 0 0 0 0 ;21. Effect
8 ffff 0 1 41 0 26 0 1 16 17 0 0 0 0 0 ;22. Effect Rot
8 ffff 0 1 12 0 27 0 1 20 21 0 0 0 0 0 ;23. Focus
8 ffff 8080 1 43 0 28 0 1 21 22 0 0 0 0 0 ;24. Zoom
4 ffff 8080 3 13 1 5 0 2 22 23 0 0 0 0 0 ;25. Pan
4 ffff 8080 3 14 1 6 0 2 24 25 0 0 0 0 0 ;26. Tilt
8 ffff 0 1 80 0 41 0 1 26 27 0 0 0 0 0 ;27. Reset
8 ffff 0 2 52 0 42 52 1 27 28 0 0 0 0 0 ;28. Control
;| | | | | | | | | | ff or 0 means unused channel
;| | | | | | | | | |__ DMX line pertainnig to this wheel (-1)
;| | | | | | | | |__ Number of chanels under control (Table width)
;|__ Wheel multiplication =16-(bits used)
; eg. for 8 bit channels it is 8, for 12 bit channels it is 4
; TABLES
; between
; FUNCTION TABLE
; __ Table width (upto 6 allowed)
; | __ Type of Table from attribute list
TSTART 1 52
Safe 12
Lamp Off 63
Lamp HalfOn 140
Lamp FullOn 217
*** TEND ***
