Pearl Tiger Problem
Posted: 13 Oct 2008, 06:47
by Soeren jansen
My all new Tiger does not allow Theater Stack programming! Somebody who has the same problem? Maybe a bug?'
Best regards
Posted: 13 Oct 2008, 08:27
by Olie
In the box with your Tiger should have been some instructions on how to set the Theatre Stack jumper. Without changing this you will not be able to use Theatre Stack.
Posted: 13 Oct 2008, 12:09
by Soeren jansen
The jumper for theaterstacking is not set from factory??? Faders etc are set as they should. Master - Ltp .... are all at the right place.
Best regards
Posted: 14 Oct 2008, 08:39
by Olie
The jumper for the Theatre Stack is not set from factory as it causes the last 5 playbacks to shift and start at 10. So with the Theatre Stack jumper you get Playbacks 1-5,11-15. If you where not using the console for Theatre Stack it would be very confusing and also would make editting chases in Unfold above 5 steps impossible.
Arghhhh
Posted: 15 Oct 2008, 08:20
by Soeren jansen
You are right. You just have to do the opposit of what the manual says.
It works fine now. Thank you very much.
Best regards
leko.dk lighting
