Theatre Stack - timing problem
Posted: 22 Jul 2008, 20:47
by BlazejB
Hello
I've been recently trying to program a continuous sequence of steps with individual timing for each step. I am a bit confused by the explanation of the usage of timing. Actually, the stack is to be built odf 122 scenes/step, each step switched to 'link on'. What's really problematic for me is that when one step has to fade out, it does not fade out when the next one comes. The result is that the steps overlap and create a bad effect, e.g. a strobe which was supposed to flash for some 2 seconds gives flashes for much longer period of time.
That is why I have got some questions:
1) what does the wait in stand for?
2) what does the wait out stand for?
3) is the fade in a part of the wait out time?
4) what, in practice, is teh fade out time? Does it mean that a scene fades out to 0 when there is no next step, or fade out to the level of the next step?
I hope you can help me.
Thanks in advance.
Blazej
Posted: 22 Jul 2008, 22:33
I have never used Theatre Stack and so cannot answer your question fully, but Wait and Fade are separate.
So Wait In time must elapse before Fade In. And Fade In must complete before Wait Out. And Wait Out before Fade Out. In that order.
Posted: 23 Jul 2008, 11:10
by BlazejB
Actually I do not know if I have to type in values for all time parts within a step or not. I suppose it is not so deducing it from Lindsay's step-by-step guidance sent via e-mail.
I would like to get the idea. Unfortunately, the manual says actually nothing really helpful about timing. In future, a short tutorial would be useful in that manual apart from an explanation of its details.
P.S. Fade out time is entered in the timing of the following step, not the one you are focused on...I suppose...
Posted: 25 Jul 2008, 23:17
by AtmosphErik
usually, any part time you do not change with the keypad and confirm with enter will remain at it's default. that should be 0.00 seconds.
