Hello.
I created a cue list with 60 cues (approx.).
When I update a cue, select the fixtures, make changes and pulse twice REC STEP.
Then pulse CLEAR to deselect the fixtures, then the console takes over 30 seconds to react to clear, but takes the more changes, when this occurs the clear button LED stays on for several seconds more. Once off, the cue list malfunctioned. No moves when you press Go or go to blows.
In short, the cue list does not update properly, the Record / Update not work, Step Record function does not work.
I've had an event and I had a really bad, I could not make the changes with sufficient fluency.
Not if someone else feels the same. As you update a cue list?.
Thank you.
Cue List big problem
Users browsing this forum: niclights and 56 guests
