Simulator Encoders
CSmithDesign
Simulator Encoders
Postby CSmithDesign » 09 Oct 2012, 00:55
Do they not work at all? I've never been able to get anything out of them, they just spin around very fast and don't do anything.
If they don't work, is there any other way to input hard values into the programmer?
Postby niclights » 09 Oct 2012, 01:12
They work fine for me. Values can be entered into the programmer in the the same ways as they are on the consoles. The software is identical.
CSmithDesign
Postby CSmithDesign » 09 Oct 2012, 01:38
How do you enter values directly into the programmer without the encoders? Obviously I know how to do it with the dimmer attribute, but what about colors, pan/tilt, etc?
Postby icke_siegen » 09 Oct 2012, 07:43
Essentially, it's like:
- select the appropriate attribute bank
- type in a number
- select the value you want to set from the soft buttons
But then, why not make simulator work as it should be? Can't be a huge thing.
- do the other controls on the virtual panel work?
- which desk do you use in simulator? If the Pearl Expert, scroll down in the virtual panel, there are three more encoders...
- if the controls on the virtual panel do not work at all, we need to dig a little deeper. It might be something like virtual panel started not from within the simulator, or the USBExpertService not running.
CSmithDesign
Postby CSmithDesign » 09 Oct 2012, 20:54
Thanks for the help on inputting values, I can't believe I've gone this long without knowing it...
The encoders on the simulator still do not work, everything else works just fine. I always use the Titan Mobile Simulator because for now that's the only Titan console that I use, so I don't know about the other simulators.
Any ideas?
On a somewhat related note, the hard keys right next to each encoder are still not used, correct?
Postby icke_siegen » 09 Oct 2012, 21:04
That's correct - I guess they might be used in future versions.
Regarding the encoders, that's _really_ strange.
Postby icke_siegen » 09 Oct 2012, 21:14
Essentially I'd suggest a re-install of the simulator.
If you really want to dig deeper:
- fire up Virtual Panel
- fire up USB Expert Console
- in the latter, Tools -> ACW Service -> Start
- now, on the Virtual Panel, turn the encoders. Do you see some values changing in USB Expert?
If yes, then it's some setting in the simulator.
If no, then it's Virtual Panel which is broken (virtually the wires of the encoders became loose, I reckon - sorry for the joke)
CSmithDesign
Postby CSmithDesign » 09 Oct 2012, 22:39
Yes, the virtual encoders do work in the USB Expert Console, but I again tried them in the simulator right afterwards and still nothing.
Do I need to re-install Titan V6? I'm pretty sure that this happened on Titan V5 as well...
Postby icke_siegen » 09 Oct 2012, 23:07
To me it looks like a weird setting in the simulator - I just played a little with some user settings (like: starting up PExp Sim, disabling the wing etc.) but couldn't reproduce your problem. I don't know what else depends from your simulator installation. But I'd backup all your shows (and personalities if you created any), do a full uninstall, reboot, install v6 (which involves another reboot), and try again. Shouldn't take you too long.
Postby niclights » 10 Oct 2012, 00:47
What OS are you running?
CSmithDesign
Postby CSmithDesign » 12 Oct 2012, 16:39
I'm running Windows 7 Home Premium 64bit.
I actually just tried it on my desktop computer, running Win 7 Ultimate 64bit and the simulator encoders work just fine. It seems to only be my laptop that won't work.
Postby niclights » 12 Oct 2012, 17:51
So is the laptop running the same and is it native (ie. not a virtual machine on a Macbook)?
CSmithDesign
Postby CSmithDesign » 13 Oct 2012, 23:53
Yes, it's an Acer Iconia 6120 running Windows. http://us.acer.com/ac/en/US/content/iconia
The only thing that I can think of is the dual touch screen interface messing with Titan software, it has done some funny things with V6, this might be one of them I suppose...
David Boots
Postby David Boots » 27 Oct 2012, 15:21
I was having trouble with the encoders also, but I found that (believe it or not) if I positioned my 2nd display to the right of the 1st display (within the widows xp settings) that they worked fine.. I had originally had it set up to be above the 1st.. I have no idea why that would matter, but it has been working fine ever since!
