I have not yet worked with the fixture creator (custom personalities). I have a few questions on how to better control a SHOWLED Chameleon star drop.
The DMX chart does not indicate an intensity channel.
How do I create one? Do I assign an unused DMX address to the intensity?
The unit requires 8 red, 8 green, 8 blue channels. As RED 1, RED2, RED 3 etc. are not typical attributes, I want to build a custom fixture that has a 'phantom' intensity channel (as noted above) and RGB. I will then patch eight seperate fixtures to represent the eight discrete zones of the drape. Will this work?
I need the intensity channel so that the curtain will fade in and out in time. I know I can apply timing to color in a playback or I can apply time discretely to that device. The problem is with the current profile, I have to select all 24 attributes individually to set discrete timing by fixture.
http://www.showled.com/site/assets/file ... meleon.pdf
DMX chart page 16
Operating Tiger Touch
SHOW LED star drop
Keywords:
- virtual dimmer
- subfixtures/cells
Essentially, you can simply use an existing fixture, Generic RGB would be a good starting point. Either you use mode 1x RGB, 3 DMX - which already has the virtual dimmer implemented. Or you just use mode 8x RGB, 24 DMX and additionally immerse yourself into the magic world of subfixtures: patch the whole thing as one unit and play with the cells using unfold or - much better - the pixelmapper.
- virtual dimmer
- subfixtures/cells
