I’m still struggling with making simple marcos for lamp on and lamp off? I have tried a few times, but it never seems to work.
My current steps are:
Macro
Record Macro
Groups and Pallets Workspace
Select group “Aâ€
ML Menu
Macro
Lamp on
Select Group “Bâ€
ML Menu
Macro
Lamp on
Select group “Câ€
ML Menu
Macro
Lamp on
Macro
I did it at full speed and it did not wotrk. But then I thought the setting for lamp on/off usually needs to be held for 5 seconds, so I did it in real time. Then it just got me to the ML menu for each group and I had to select macro and amp on myself?
What other typical macros do people use? Im really struggling to find reasons to use them. I do a lot of things repeatedly (like updating pallets at every venue), or creating pallets for different makes of fixtures at the beginning of very programming session… but I don’t think I can use a macro to do that for me?
What do you use them for?
Lamp on /off Macro?
Wherever a fixture macro is named the same the software will attempt to follow the rules for multiple fixture types simultaneously, so you can make this simpler by using a group that contains all fixtures and fire one 'lamp on' command (from the fixture macro menu you will notice 'lamp on x', where x is the number of fixtures that contain an identical macro).
My method would be to use the numeric reference to the group:
- Create a group of all (relevant) fixtures. This could be one assigned to a handle or just numeric if you don't want it to get in the way.
- Make sure you are in the root menu.
- Record macro.
- Type group number on keypad.
- Press group key
- ML key
- Macro
- Lamp On
Personally my favourite use of macros is for creating intensity chases:
- Before recording macro select some fixtures (is not important which) and begin recording a chase.
- Record macro
- Next
- [Append Step]
- @ [0%]
To use this you can then select a group (making use of fixture order/selection pattern if you like). Start to record a chase then enter number of steps on keypad followed by macro. This will repeat the macro x times creating an intensity chase x steps long.
Olie had a great suggestion too about a macro that sets fixture overlap values for busking palette recalls.
- Record macro.
- Press group key
- ML key
- Macro
- Lamp On
- Record macro
- Next
- [Append Step]
- @ [0%]
O great!
But if the lamp on macro in ML Menu now works over multiple fixture types, then I don't really have a need for the macro anyway
(seems it would mainly be useful in an automated timecode type show?)
Thanks for the intensity macro, and the release macro. Maybe we should make a thread of useful macros like the tips and tricks one? But I'll make a doc for myself with them in anyway...
Could I write a macro to release the cuelist, change to specific page, and activate next cuelist? I currently have a show with 18 different songs, each on a different page. The order of the songs could change every night, so I could then just program the macro before each show when I get the setlist and it will run the correct order of the songs?
I'm struggling with the same problem using 3 types of fixtures.
Both ways don't work for me. Problem is that 2 types of fixtures have their 'Lamp On' macro on softkey A (MAC250 and Showtec Explorer), and the Robe XT250 wash has the 'Lamp On' macro on softkey B.
Is it possible for me to make this macro?
niclights wrote:Wherever a fixture macro is named the same the software will attempt to follow the rules for multiple fixture types simultaneously, so you can make this simpler by using a group that contains all fixtures and fire one 'lamp on' command (from the fixture macro menu you will notice 'lamp on x', where x is the number of fixtures that contain an identical macro).
Seems that this doesn't work because some fixtures have a Macro 'Lamp On', and others 'Lamp On,Reset'.
Thus, you need to alter Nic's second suggestion:
niclights wrote:My method would be to use the numeric reference to the group:
- Record macro.
- Press group key
- ML key
- Macro
- Lamp On
to
- Record macro.
- Type group number of fixture type 1..x on keypad.
- Press group key
- ML key
- Macro
- Lamp On
- (wait some seconds, and playback in real time)
- Clear
Repeat as many {} sections as you need. The Wait and Clear are guessed, but don't hurt.
Users browsing this forum: No registered users and 87 guests
