Cuelists on Executer buttons
peter.rodda
Postby peter.rodda » 13 Sep 2011, 14:34
Is there a way to run cuelists at full intensity on executer buttons?
Seems to work from “Playbacks” touch screen, but cant get it going off executers. I tried with a key profile that has all the keys set to “Go”, but that didn’t seem to work.
Postby niclights » 15 Sep 2011, 10:18
Testing in v5 it seems to work fine from default although it's possible this is something that has changed.
You want the keys to be set to latch. According to v5 the executors are treated as 'touch' keys. The easiest way to be sure is to select a key profile to edit and then press the executor containing the cue-list. This will take you directly to the options for cue-lists on that particular key type. Then select 'latch'.
