updated Tiger touch 3.1 to version 4.2
Vida26
Postby Vida26 » 22 Jul 2011, 14:48
Hello, I need then updated my new tiger touch with version 3.1 and I downloaded the avolite tiger touch 4.2 version, but I do not understand how to upgrade her. Only you should download the tiger touch v4.1 setup file and upload it to a flash drive and open it from the console?
i thank you for help me
Hola, necesito actulizar mi nueva tiger touch que vien con la version 3.1 y he bajado la version de avolite tiger touch 4.2, pero no entiendo como actualizarla.
Solamente hay que bajar el archivo tiger touch v4.1 setup y cargarlo en un Pendrive y abrirlo desde la consola?
Postby icke_siegen » 22 Jul 2011, 15:42
A detailled howto for upgrading is given in the release notes: http://www.avolitesdownload.com/Support ... Notes.aspx
Essentially, there are two ways: either you download the 'small' upgrade package, put it on a thumbdrive, an run it. Or: you download the full installer (in particular if you want to have language support) to a separate PC, and follow the instructions (make thumbdrive bootable). Actually, for an Upgrade from 3.1 to 4.1, I'd always recommend the full installation (Recovery stick).
And finally: do not forget (a) to backup your data, shows, and custom personalities, and (b) install the latest fixture library.
iwan hutapea
Postby iwan hutapea » 29 Jul 2011, 09:51
Hi there,
i could only find the Ver 4.1.9
where i could find Ver 4.2 ??
Postby niclights » 29 Jul 2011, 10:07
4.1.9 is latest for TT and Expert. 4.2 is latest for mobile/simulator.
