some questions about "cue list"
nrdgnr
Postby nrdgnr » 12 Jun 2011, 20:08
Hi ,
i have two question for tiger touch ;
the first question is :
i want to copy a cue from the cue list and i push the unfold button then select cue list , after pressing copy button and selecting cue which is want to copy then i want to paste next empty button pressing by blue playback button but desk says : "select a handle to copy onto.You can't put that there"
is there any way to copy a cue from the cue list?
and second question is :
is there any chance to record cue list live ?? (i mean record real time..)
thanks.
EmmaThompson
Postby EmmaThompson » 18 Jun 2011, 21:39
1. The way to do this at the moment is to include the cue and re-record it:
in unfold, press 'include', then playback swop of the cue you want to copy. You can then re-record this as a new step.
2. Not sure what you want to record "live", do you mean timing?
Emma Thompson
Training and Events
nrdgnr
Postby nrdgnr » 20 Jun 2011, 21:42
hi again ,
i mean , like "script file programming" on azure, i would like to turn playbacks on/off and desk will record my playback changes with time.then i will fire this file by winamp timecode. is it possible for titan?
thanks for the answers
EmmaThompson
Postby EmmaThompson » 21 Jun 2011, 15:53
There is no real-time script file programming on Titan, you can now assign cues from a cue list to timecode. Timecode can be triggered by MIDI, Winamp, the external clock or internally.
Emma Thompson
Training and Events
Postby niclights » 21 Jun 2011, 19:43
I'm not sure if it's quite what you want but I do have a possible two-part solution:
First setup a cue-list with autoload playbacks in the correct order. Then set the timing live.
To setup the cue-list:
-Record Cue-List
-[Advanced Options]
-Turn on [Autoload Live Playbacks]
-Lift playbacks that you want to fire in the first cue.
-Store cue
-Lift playbacks for second cue.
-Store cue.
-etc.
Once you have build the list you can set the timecode points in real-time:
-Fire Cue-List and make sure is connected.
-[Timecode]
-Set timer source (ie. Winamp)
-[Record]
-Start the source time
-Press Go to set the timecode point for each cue in turn.
-Finish recording by pressing [Record] again.
-[Connected Cue-Lists]/turn on the list(s) to be controlled by timecode (this can be done by toggling the softkeys or by selecting the playbacks themselves.
-Reset the source timer and test.
-Manually edit times as required.
If you want the first cue to fire immediately then after pressing [Record] you could fire the first cue while the timer is paused which should ensure it is recorded at 0sec then begin the source timer and continue real-time settings from cue 2.
