Azure Shadow, a serious problem
Tasroni
Postby Tasroni » 21 May 2011, 15:42
Hi All friend....
Azure I was always in trouble, I rarely use it only once a week, when I first turn it always fails at loading into the keypad, on the internal display shows when (VDU!) always come back to the beginning, the display did not want to enter (OK).
and when I hold-hold on the motherboard and turning it on again, then he will be OK.
I even think that the ribbon cable (DB) that there is a problem, but I do not think so because when I was off the cable, the same problem unresolved. until this moment I am still confused with this problem.
- what problems might exist in the power supply?
- or on the device lauin?
Please tell my friend that I could get out of this problem, which I fear when the show is running problem comes then this would be a serious problem.
thanks
I respectfully
tasroni
Postby niclights » 21 May 2011, 22:41
Often problems starting are caused by old motherboard battery.
Disconnect power. Measure battery using a multi-meter. It should read 3.6v. If it is much lower then this is probably the reason. It should be an easy part to get and replace.
Contact Avolites service for more help.
Tasroni
Postby Tasroni » 22 May 2011, 05:31
Hi Niclight
thanks for the explanation, and I'll try it.
Note:
This motherboard has experienced serious problems, so I decided to fix the AVOLITES LONDON, and indeed the battery circuit was damaged. so that the repair team avolites soldering battery socket by using fiber cable to connect to the IC.
How long battery life can I use?
battery replaced in February 2009 on motherboard repairs in London.
I am waiting for an explanation from you, maybe this will be helpful for solving this problem.
Thank you
Tasroni
Postby Tasroni » 23 May 2011, 08:01
Hi Nicklights
Plesa help me.......
Many Thanks
Tasroni
Postby niclights » 23 May 2011, 11:07
I'm sorry, I cannot help further. Please email service.
zahoorjury
Postby zahoorjury » 31 May 2011, 00:49
@ tasroni, also check the main power supply unit, may the main board battery is to remember & remain the memory while the console is in Off state.
EmmaThompson
Postby EmmaThompson » 31 May 2011, 17:40
If you have hardware problems, your best port of call will ALWAYS be our service department for the most accurate, and often fastest, answers.
repairs@avolites.com
0208 965 8522 and ask for Lee
+44 07831 178 888 for out of hours tech support
Emma Thompson
Training and Events
