Crashing Pearl 2004
triff
Crashing Pearl 2004
Postby triff » 28 Sep 2005, 14:09
Been using a Pearl for nearly 3 years now and never had a problem. However last night mid show our Pearl suffered a major problem.
It appeared to crash in some way. All the playback faders refused to run. The preset faders brought up lights no problems and behaved correctly. However when you raised a playback fader the desk acted as though nothing had happened. Nothing was shown on the screen. No moving lights would locate.
I'm going to reinstall the lastest software on her today in the hope that it won't happen again, but if anyone can shed any light as to how or why this happened that would be awesome
Many thanks
Alex
Edit: should point out its a 2000 with 2004 software on!
Postby niclights » 29 Sep 2005, 00:08
Oh dear! That was naughty :shock:
I've never experienced anything so drastic. I have occasionally experienced slow running after complicated programming sessions or wierdness from a cold start when the desk has not been used for a while. (I put the latter down to old battery)
Any issues I have encountered will normally cure with a press of the reset button. Did you try this or turning off/on the console?
I will ask a stupid question... are you certain you had not accidentally changed roller page (as in 1/2/3, not facet!) ? I ask because this happens quite often in my experience.
Things to check:
System/Service/Bus Errors - there should be no errors.
System/Service/Diagnostic Screen - check PB faders are outputting correct values.
If not, open console and check ribbon connectors to analogue board. It is probably worth affirming the seating of all the main chips on the motherboard at this point & all other ribbons just in case.
HTH
/Edit: Re-read and remembered the locate thing, so I guess it was a stupid question!
triff
Postby triff » 29 Sep 2005, 02:04
Started with the reset button....didnt work, turned on and off console.....didnt work!
Oh i know this mistake all too well, but this wasn't the problem. I've caught enough people out with that kind of gremlin to know better myself :D
Things to check:
none
There is one fader that is playing up, but I knew about it before so hadn't programmed onto the fader. And today I got round to replacing it!
Did all that last night, but presuming that a wipe all fixed it I dont think that could be a problem could it?!
Well i reinstalled the software, installed a new floppy drive and replaced a fader today so I guess we'll have to see if it happens again.....any other suggestions? :D
Olie
Site Admin
Postby Olie » 29 Sep 2005, 09:56
It sounds like a hardware problem because you mentioned that the LCD screen was blank. If the software crashes it is very unlikely that it would cause the LCD screen to go blank.
triff
Postby triff » 03 Oct 2005, 00:18
I feared a hardware problem........ lets hope it's not and it never happens again!
jgubby
Postby jgubby » 06 Oct 2005, 15:51
If you have ever been tinkering inside your pearl, it may be worth venturing back inside to check the ribbon cables. I had a similar problem where the screen was refreshing without any data on it, and had forgotten to plug a ribbon cable in. Perhaps one has come loose?
James
triff
Postby triff » 03 Mar 2006, 13:04
it's back!
Only this time it crashed with bus errors.....something about video then a hex numbers. So i removed the video card and all seems fine. I never use the video card so can i presume this was an ok course of action?
iadwm
Postby iadwm » 03 Mar 2006, 14:51
triff wrote:it's back!
Doesn't that indicate the old fave - loose card/cables?
I guess removing the card does put a full stop to the problem (hopefully).
Fingers X !
Andy
John Peel
www.iadwm.com
Beaker
Postby Beaker » 19 Mar 2011, 20:08
Mine did the same thing last night. Did you ever figure out what happened?
Beaker
Postby Beaker » 19 Mar 2011, 20:31
Battery? Mine is over 5 years old.
EmmaThompson
Postby EmmaThompson » 20 Mar 2011, 15:50
have you tried contacting our service team?
During office hours you can get hold of Lee or Tommy by calling 0208 965 8522 and asking for service, or our out of hours number is 07883 1178888
Emma Thompson
Training and Events
Beaker
Postby Beaker » 22 Mar 2011, 16:58
Hi Emma. I will open it up this week in the shop and check the battery. It's been over 5 years, so it's the logical suspect. Will let you know (and others) here.
Beaker
Postby Beaker » 30 Mar 2011, 20:58
Well got it open in the shop today. Ribons all look good so far. I put a VOM on the battery and it reads 3.6, but it's still in the circuit. It may be reading left over voltage in a cap. I'm letting it sit over lunch and will test again. If the batt and ribbons are OK, it's a call in to tech support. BTW- memory tests come back fine.
Users browsing this forum: No registered users and 169 guests
