pre-setting chase speed - Pearl Tiger
ajh51
Postby ajh51 » 15 Sep 2010, 13:58
Hi all,
I'm slowly getting to grips with the Pearl Tiger that I operate at church but I have a chase question that I've not found the answer to on here yet.
I have a dimmer chase running on my blinders that I'm using to step through the row of blinders in turn and then finish on the last step - which is all the blinders on 100%.
That all works fine and I can set the speed of the chase during programming and during playback, but I'd like to be able to override the default speed BEFORE I trigger the chase. Ideally I'd tap in the beat of the music and then when I trigger the chase it is already in time.
Is there anyway to connect to a chase that isn't running to do this?
Also I've read about a bug in the tap operation... is that bug present in the Tiger too?
Thanks,
Andy.
Postby niclights » 15 Sep 2010, 15:04
Unfortunately this is not possible on the Tiger.
I don't know about the tap issue.
ajh51
Postby ajh51 » 15 Sep 2010, 16:16
Oh well, I'll have to think of something else then..
I guess I can always control it manually using the stack and the go button... ...time to go back to the manual.
Anyway, thanks for the quick response.
Andy.
ChiekuRs
Postby ChiekuRs » 15 Sep 2010, 19:03
you can rise fader just a little (few % is enough) - chase will start to run and you will be able to control chase speed, but no actual output will be visible. However this is true only for HTP (intensity) chases.
Users browsing this forum: No registered users and 109 guests
