Tiger Battery
Tiger Battery
Hi every one , my tiger doesn't want to boot and giving my the lovely whit and blue lights without no thing there ,,,,so i open the disk and the check the battery and i find it almost zero !!!!!! is it normal for the battery to be worn or become 1volt after less than 1 year of usage !!! my disk is brand new with the plastic protective bottom sheet still there !!!!! any how i got to work so i got new battery and before replacing it i measure the volt across the battery in the Boris mother board before inserting the new one ,, and i found that there is no volt for charging !!! any body have any clew it should be DC source to charge the battery ,,, i dont want to destroy the new one .....could any body help
OK and thanks .. i just didn't expect that a console with that technology and good reputation like Avo tiger to have a worn battery after one year ,,i have some Zero 88 console working for 7 years till now with VARTA battery working like a rock ,,,,, OK i will replace it and re license ....thanks again
niclights wrote:I think you should contact service direct and find out what is known about this problem and how they can help. I'm sure it's not normal. Even an old 2000 console I have here is still fine after almost ten years.
i already contact them and they said replacing the battery is the solution for this problem ...
Users browsing this forum: Bing [Bot] and 73 guests
