chase problem pearl 2004
dennisvddool
Postby dennisvddool » 25 Aug 2010, 17:44
Dear fellow knob-pushers :)
I have a problem with a pearl.
When i make chase it al goes well. After programming pushing the fader up the chase starts as it should.
When the fader goes down it the chase stops as it should.
And now the funny part starts:
When i push the fader up again the chase doesn't start untill i hit go!
I went through every menu available, re-installed the software.
Nothing helps!
Is there anyone who knows this problem or a way to fix this??
Thanks in advance!
Greetz, Dennis
Postby niclights » 25 Aug 2010, 19:10
This sounds like the chase might be set to 'fader stops, go to start'.
Program mode.
Fire chase.
[Chase Parameters]
[More...]
Toggle softkey A until it reads [fader will reload chase].
See if that helps.
dennisvddool
Postby dennisvddool » 26 Aug 2010, 10:59
Thanks for your reaction!
Already found that function, but that doesn't seems to be the problem.
It's on "fader will reload chase".
That's the weird part.
Any other thoughts?
Postby niclights » 26 Aug 2010, 12:55
Unfortunately not. This is one of those things that sounded vaguely familiar but I was hoping it was the chase option above.
Does it only happen with one chase or all? If it's only one can you re-record it and see if it is ok on the new version?
dennisvddool
Postby dennisvddool » 26 Aug 2010, 15:20
It's in every chase i build.
So i still think (and hope) it is a software thing.
