I loaded an R20 profile for the color blast with the virtual dimmer. However, the dimmer channel does nothing, and its still completely controlled by RGB channels. Do I have to change something to make it work?
Board: Azure 2000
Color Blast profile proble with Virtual dimmer...
Muvment Lighting
The Azure doesn't have virtual dimmer. Perhaps you mean the personality with pending dimmer. This is not the same thing - it allows you to patch a normal dimmer on top. A more typical example might be a VL5 with a tungsten lamp powered from a dimmer which will obviously have a different address to the fixture.
- john rogers
