make a step go in reverse in an unlinked chase?
Tumbleweed
Postby Tumbleweed » 20 Dec 2009, 03:32
is there a way to step backwards in unlinked chases on a Pearl 2008/2010?
Postby niclights » 20 Dec 2009, 13:01
Set direction to reverse?
Tumbleweed
Postby Tumbleweed » 20 Dec 2009, 22:24
let's say I just want to go from 1,2, and 3 of a 10 step chase... then I want to go from 3, to 2, to 1....
that's what I meant
Postby niclights » 20 Dec 2009, 23:14
Same answer. Change direction after step 3.
Ari-
Postby Ari- » 23 Dec 2009, 13:30
Jumping to steps would be possible? In his example, instead of going 1,2,3...10; when raising the fader and hit GO, instead of the first step, to go directly to step 6 for example.
By using the arrows to navigate through steps I always lose the fade/wait in-out?
Postby niclights » 23 Dec 2009, 16:32
Sorry, I'm not sure if that was a question or not?
To clarify, if there is a change of direction when using the chase control buttons it does not snap to the next step. So this would not be a problem. Otherwise I always found that a useful feature. I can't remember if there is a difference when Fixture control is enabled and you use the arrow keys instead, but I didn't think so.
To jump directly to a step enter the step number followed by Connect. Pressing Go will then go to that step with associated timing. This works for theatre stack too. I don't think it was ever documented.
