I havea pearl 2004 (2000 board with upgraded software) and on it I am patching 63 Mac250 Entours, 10 Mac500 m-4s, 1 Antari X310 Fazer and 60 dimmer channles. No matter what I do I can't get the last 3 fixtures that I patch to take the macro control commands. When viewing the channel output for the shutter for the last 3 fixtures patched when the macro command is sent they don't get assigned any value.
See you on the dance floor,
JQ.
Help : Pearl ML macro problem.
See you on the dance floor.
Jason "JQ" Kew
ORT Audio and Lighting
(647)226-9318
continuum_lx@yahoo.ca
Jason "JQ" Kew
(647)226-9318
David.Hunt
I do not see how this can be a personality problem since most of the other fixtures work.
This does ring a bell though and I think it is a bug in the software. From what I can recollect, the macros do not work on fixtures above a certain total channel count. I thought this was fixed though, are you using the latest Pearl 2008 software?
Without wishing to confuse things further...I thought you could, BUT only if you were willing to loose the internal cache?
Regards,
Andy
Regards,
Andy
John Peel
www.iadwm.com
John Peel
www.iadwm.com
And do you lose the cache or have I made that up ?
Cheers,
Andy
Cheers,
Andy
John Peel
www.iadwm.com
John Peel
www.iadwm.com
Olie wrote:You can install 2008 software on 2004 consoles but you must first install the USB board hardware modification. If you have not got this modification then you should have version 1.2 of the 2004 software installed.
How much is this USB board mod and what would happen if I didn't get the mod and install the upgrade?
