trigger azure 2k from midi foot pedal
Hi i got an azure 2000 on demo today, I am looking to trigger scenes from a midi foot pedal but what is happening is that the pedals change pages or (banks) only, how do i go one step more to select scenes within a bank?
From the manual:
Normally you don't need to worry about all the codes. The important bits are:
Program Change = Change Playback Page.
Note on = Turn on Playback.
Velocity = Playback level.
Aftertouch = Chase controls.
You need to look at the details of your controller to see how you set it up to output what you need.
MIDI commands used by the Azure
The Azure uses standard MIDI commands. The usual name for these
is given in italics. All commands are given in hexadecimal notation
($9n), where ‘n’ is the MIDI channel number. So a note on command
for MIDI channel 3 for example would be $92.
Set playback page : program change ($Cn xx)Code: Select all
Page A B C D E F G H I J
xx $7F $02 $03 $04 $05 $06 $07 $08 $09 $0A
example $Cn $02 Console changes to Page B
Turn on a playback: note on ($9n pp ll)
Note number (pp) = playback number, from 0 - 49 (decimal)
Key velocity (ll) = playback level, from 0 - 127 (decimal)
example $9n $03 $40 Playback Fader 4 at 50% level.
Playbacks on buttons cannot be set at a % level, only playbacks on
faders (1-10 on each page).
(Note that Playback Fader numbers start at zero, so subtract one
from the number on the console to get the MIDI note number).
Stop/run/step a chase etc: after touch ($An pp cc)
Aftertouch value (cc) = control codes:
$00 stop chase
$01 run chase
$02 restart from step 1
$03 fade to next step using programmed fade times
$04 Snap directly to next step
Users browsing this forum: Bing [Bot] and 36 guests
