My english is not very good but i hope that some one can understand what i mean.
If i make a shape with the shape-generator, and i want to put him to a playbackfader.. he says that i have to select a <SWOP>... when i try that.. he doesn't put him to a playbackfader.. exactly he does nothing..
can some one help me with this little problem?
thanks and reggards,,
Pearl simu problem
zwartlicht
That should work fine. Perhaps you have made a small mistake?
To confirm, this is procedure:
Key to Program Mode
Select fixtures
[Shape Generator] softkey
[Playback a Shape] softkey
Choose shape. ie. [circle]
You should now see fixtures moving in a circle (assuming you have intensity up!)
[memory]
Select a flashing (empty) playback SWOP to store.
[clear]
Raise the playback and shape should run.
Key to Program Mode
Select fixtures
[memory]
[clear]
